DP-C405 J81 !!!!
  • mojorolla
    The Wolf
    • 2639
    [Jamming] DP-C405 J81 !!!!
    I have 3 Panasonic dpc-405 with j81 when running duplex. Page enters the ADU turnaround section and advances too far, catching on the sensor (ADU 0) when going down into the ADU unit. I had this on a dpc-322 and replacing the clutches worked, but not on the 405. So far I have replaced both clutches in the trunaround, all sensors and actuators, an ADU pcb, paper transport unit, removed the finisher due to a known motor issue, and adjusted the ADU paper loop, but still getting j81. Happens on all sizes from all drawers. Several of the afore mentioned parts were at the request of Panasonic tech support; I think I stumped them. I have even taken a working turnaround unit and the problem still persists. Thank you all in advance.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • 20gaugeO/U
      • 557
      Hate to say it but firmware loaded twice? SC: 10027 EC: 10013
      Have you tried it without the transport unit on the machine?
      • mojorolla
        The Wolf
        • 2639
        Yes and yes, including a shipment set. Also without the transport and with a new one out of the box.
        • 20gaugeO/U
          • 557
          405 is the 3rd generation. Have you been using ADU's, transports and boards from 322's and 354's? Some of boards and wiring look the same but are not interchangeable. They'll change one connectors wiring so it's not compatible. Great design...
          Sounds like a SC/EC board issue if an entire mechanical ADU section from a working unit fails.
          • mojorolla
            The Wolf
            • 2639
            All parts used are from the same family, 405's. I have also swapped out an EC board and am waiting on an SC this week.
            • The-Peanut
              • Aug 2006
              • 192
              yeh i would have gone with the EC board next, followed next by the SC board, i just had a strange 1 myself recently, where i was getting J27, i finally sourced the problem to the SC board, the F2 fuse had blown,
              • mojorolla
                The Wolf
                • 2639
                The SC has 2 green leds upper right corner and 1 red led damn near under the memory card. The EC has 4 leds. I always check these first, especially the EC. I am still waiting for my SC board from Panasonic. As soon as I fix this mother, I'll post the fix. Thanx for all the input.
                • mkb
                  • Sep 2010
                  • 23
                  Have you unplug the hard drive I have had some wierd stuff when the hard drive goes nut don't know Monty
                  • mojorolla
                    The Wolf
                    • 2639
                    Hell, that's the first thing to do on any Panasonic...lol.
                    • JVergin
                      Service Tech / IT Rep
                      • 216
                      I have had this problem before a few times. replace the clutch in the transport unit. It's a clutch with a blue gear P/N L9EAAK000006. Drives it too far past the sensor flag then rams into the flag when attempting to go into the adu.
                      • Logged-on
                        • Sep 2010
                        • 197
                        I was thinking transport too, but he said it still occurs with it removed.
                        I know of a few things that might cause specific jams issues, I'm not sure if it was J-8x's or not but maybe a couple things you could check for. First I have seen where the customer will bend the frame that has the the cover switch on the right side. It will cause the machine to see an open cover in the middle of a copy run, and you end up with a jam at the end.
                        Next I have seen the black rubber paper path rollers wear, and cleaning them has solved some jamming issues. and finally I only saw the part out of the machine by another tech, but the plastic paper guide under the IT belt was worn on one side but not the other, I think I have related a couple problems to bent frames, or cracked plastic around the hinges.
                        • mojorolla
                          The Wolf
                          • 2639
                          JVergin, you win a prize! Two of the three were the transport clutch. Turns out the ones we had were used...ugh. The third ,the one I was fighting with,turned out to be a retrofitted motor in the finisher causing electrical noise. Thanks to all.
