Panasonic DP-C354-scanning to network folder
+ More Options
Posts
  • Da_siz
    • Aug 2025
    Hi All,
    I am looking to set up scanning to a network folder, but thus far cannot see how to do this. I have looked around on the net and from brochures etc it does seem possible, but there is no info on how to set this up.
    Any info would be much appreciated.
  • Luong Nam
    • Oct 2009
    • 49
    You must install:
    - Network printer driver
    - Communications Utility
    Communications Utility is used to setup scanner.
    • Da_siz
      it is currently set up to print from a networked pc..
      and also users are able to scan to email, thus i would imagine the communications utility would have been installed.
      On the webpage for the unit i just cannot see anything to set this up.
      • Luong Nam
        • Oct 2009
        • 49
        Panasonic don't have webpage.
        You open Communications Utility to setup it.
        • Da_siz
          yeah it does, you can see device config, network config, consumables etc
          • Luong Nam
            • Oct 2009
            • 49
            It use IP address of network printer to scan to PC. You setup the link where to save a file by Communications Utility.
