Dp-6030 is dead after replacing drive unit.
  • PanaTech
    • Dec 2008
    • 71
    I have a dp6030 which originally having duplex jam problem (j80). I replaced a drive unit, machine turned on fine, but then after 23double side copies, n it shutted off by it self. I replaced the original drive unit back in, it didnt work. So far, i have replaced: SC broad, SPC broad, Drive broad, all power supply, ADU, and even that little circuit where the plug goes it..... It still not responsing. I have replaced the switches as well. It did not blow any fuse. It just quit. Customer has been a week without copier, n pissed off. Please advise.
  • The-Peanut
    • Aug 2006
    • 192
    check the pnl pcb located under the touch display, the on/off switch feeds from that board, it might be an idea to check the psu, its located behind the front panel beside the lct, check the connectors from the smaller of the 2 psu's, u can located them at the back.
    when u switch the machine on, doe the display flicker at all, or is it completly dead?
    • PanaTech
      • Dec 2008
      • 71
      I will try to swap the panel tomorrow, n test the power supply. But i have replaced all the power supply on the machine.
      It just dead. No response at all
