J 97 Error code Panasonic DP1820 Copier
  • MPM2140
    • Mar 2010
    • 13
    [Error Code] J 97 Error code Panasonic DP1820 Copier
    Copier makes a copy and then continues to run on and then an error of J 97 occurs.
    This error is not in the book... has anyone had this error and how do I fix it.
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    I believe I've had this jam code as well. My memory's no so great, but I believe I had that J code at the same time as having the E03-10 code. The page would just stop in the path and show the J-94 code. Once the paper was removed the machine would give the E03-10 code. Once we installed the ground update to get rid of the E03-10 code we didn't have that jam code show up again.
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
    • HENRITECH
      Is this Every Page?
      Have you checked the fuser exit sensor function?
      Sounds like it is not seeing end of the page.
      • Bani
        • 34
        I hope this is the solution for your problem.
        Bani
        • kashif abbasi
          this problem is coming from exit sensor, and duplex sensors, so please checq ur sensors, i hope you will solve this problem.
