Please help!! From a fellow tech.--
I have a 6030 in particular that has been locking up the fuser web and making that noise that we all know well. These junk machines are killing me!
This machine I have replaced Drum unit, Developer then Developer unit, Transfer Corona assy., tinkered with fuser temp/TDC gain vtg., Fuser(3 of them) with different Web assy. each time, Web assy gear and one way arm for solenoid.
I have run the machine with door open and the solenoid for the web works, its just that the oil web gets covered with toner every time then it starts to squeel.
Have tried different oil webs from Katun and another aftermarket because Panasonic admits their webs do not have enough oil, even suggested to us to add oil!?!?!?!?
Sooo, my main problem is that in addition to I will run any number of copies(20-300) then after the job I run 1 single copy and it has toner on the back of the page from the pressure roller being dirty.
I am thinking it has to be either the Fuser roller not being cleaned properly, or its not getting hot enough therefore leaving residue toner on fuser roller which in turn transfers that to the press roller.
I am losing my mind, if anyone could help me out I would appreciate it, I am sure a lot of us are dealing with this and Panasonic does not seem to care with the suggestions they have given us.
THANKS!!!
THANKS!!!
