Panasonic DP190 settings
  • xxmandingoxx
    • Jun 2011
    • 61
    [Misc] Panasonic DP190 settings
    allrighty, on the op panel of a DP 190 there are 3 settings Text / Text Photo / photo
    this is the machine i use in my office lol, and the only way it works is if its set to TEXT or else copies are blurry, and ive replaced a bunch of stuff out of used machines and no luck but as long as it is on {TEXT} copy type, it prints great with good CQ
    any way to set it so TEXT is always highlighted instead of always defaulting to text photo?
  • mojorolla
    The Wolf
    • 2627
    Press the COPY button on the left side of panel. Then FUNCTION, scroll to COPIER SETTINGS, hit the SET key, scroll up until you see KEY OP MODE, hit SET again, enter 3 zeros as the password (000), hit SET again, scroll down until you see ORIGINAL/HOME, hit SET again, press 1.Text, hit SET again to hold the setting. Hit the red stop key twice to get out. Should be good to go.
    • xxmandingoxx
      • Jun 2011
      • 61
      thumbs up sir, thanks
