Dp-1520 helpppppp
  • ebulich
    • Jul 2010
    • 46
    Dp-1520 helpppppp
    Have a client with a DP-1520 that gets very intermittent marks on the printed page that could be best described as an arc type image.
    I did hear that Panasonic did have some problems with these machines with static build up or arcing and they actually had a kit produced where you could attach a wire to the frame of the machine for grounding.
    If anyone has heard of this PLEASE i beg you to respond. I actually downloaded a pdf a number of months ago - because i thought it was interesting and knew that we had a few clients with this machine. Now do you think i can find that file anywhwere.
    All help greatly received.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
    Paul@justmanuals.com
    • onetek
      • 318
      Is this the tech bulletin you refering to?
      On these copiers, ghost immages can also be caused by old drum/blade, or dirty heat roller due to non oem toner. also the charge corona can leave marks too.
      Th.
      • ebulich
        • Jul 2010
        • 46
        onetek- you are a scholar and a gentleman. Thats exactly what i was looking for. You are a life saver - thank you ever so much.
