problems at DP-8016P
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] problems at DP-8016P
    hello well l have copier PANASONIC DP-8016P ..this copier not function and he affiched ( Tray No.1 ) ADD PAPER ....l cleaner all her component ( silonyde ...gear ...) well can anyone help me ??
    BEST TECHNICIAN . NICE PEOPLE .
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      unfortunate l not need anything from yourself
      • onetek
        • 318
        If you can make copies from bypass, then your tray #1 paper lift motor casings need to be replaced. Otherwise, you probably have a E04-01 error: fuser temp error. You got to get to F8-06 mode and check the errors there.If you have E04-01 error, you need to fix the problem and clear the error with F9, ram initialize, lbp fuser reset.
        Th.
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          Re: problems at DP-8016P
          well nothing ...l tray more solution but unfortunate this copiers not knowing the paper ...always he affiched TRAY N.1 ADD PAPER ...real if l check one paper for bypass the detector indicate paper but in bypass section but the empty paper always indicated ..l think l should be found the driver and frimware ..pls if anyone have sending by my email : mecanographe@gmail.com
          • Logged-on
            • Sep 2010
            • 197
            I agree with onetek, I don't know from what you have typed or not if you tried to do an LBP fuser reset or not, but that is the first thing I would do. There are lots of functions that get locked out without the true error being shown. The LBP fuser reset is the easiest and most likely cause of a paper lift error. The only trays that I have seen paper lift motors fail are legal and ledger, or the large size papers, if they are using the tray for letter or approximate, I don't think the lift motor would break unless the rear guide was broken, which might allow the paper to slide backwards, causing the motor to overdrive. If you run your LBP fuser reset, once you reset the power, you should hear the paper lift motor begin turning, if it errors out after that, you should replace the whole motor assembly, or inspect the inside and order the plastic that has cracked.
            There is one more possible cause I can think of, there is a paper present sensor/actuator that should hang down somewhere near the feed rollers. I have seen these break on rare occaisions. I can't say I've had to replace on one of these models, but on a 2330 it's a real pain.
            Another thing that just occurred to me. The bypass tray actuator could have popped out of it's holder. If that is the case, the copier will always default to the bypass tray, and never see that the paper is present. After you remove the side door the bypass should come off relatively easy. Check the actuator on the bypass to make sure it is properly in place.
            I hope this helps, Good Luck.
            • zaza
              MECANOGRAPHE
              • Mar 2008
              • 1095
              it's ok ..the long explication ...but l informed you ...today l change all sensor ..all detection paper ...but unfortunate anything to be changed ..l think l should be found the frimware for raison to updating all programme ...pls if anyone have it sending me at my email : mecanographe@gmail.com
              • zaza
                MECANOGRAPHE
                • Mar 2008
                • 1095
                Personal attacks are prohibited in the rules of the site. I think it's time you found a new place to beg for stuff.
                I just received another invoice from the site op. There will have to be some changes before I pay it. He just may have to enforce his own rules. Say goodbye.
                stupid plumber he provoke me in all my requests thread after there he said l broken the rules ...if you are gentle don't said your opinion about my requests thread ..l remember you ..your bad document is not necessary for me ..what's that ..l buying your fuck document or l am crazy ..where is this strange rules !!! ..really it is very stupidity ..let's me alone big dada ...l know you assisted for my tow red card ...but I am not afraid
                • mjunkaged
                  • 386
                  Firmware usually doesn't fix common problems. You did not READ and LQQK at the posts given to you.
                  Firmware only fixes Samsungs. Not real machines. Panasonic DP series rarely require or even HAVE updated firmware. PLus, you should not update firmware except as a last resort. GOOD LUCK getting anythying Panasonic. Gotta be a dealer for special stuff like that, bub. And there are no more dealers just distributors (hint, hint)
                  PS: not to be mean but get a better translation program. Or have your kid type for you.
                  • zaza
                    MECANOGRAPHE
                    • Mar 2008
                    • 1095
                    well l not think so ..because l tray many solution to result this problems ..but nothing ..l clean all sensor ..l change a cassette motor by other ...but also never ..this dp 8016p not knowing the feeding paper ...if l chosen between paper by pass and cassette l find the same message ( TRAY N.1 ..ADD PAPER ) and paper icon tray lighting indicated not paper ..pls l search any idea ?
                    • JustManuals
                      • Jan 2006
                      • 9838
                      It already looks like his kid is typing for him.
                      Why don't you get one of your Russian friends to get it for you?
                      • zaza
                        MECANOGRAPHE
                        • Mar 2008
                        • 1095
                        Stupid fuck plumber it is my personal thread if you are regular men take far way my thread ..but if you are an animal fuck creator ...unfortunate ..l am not responsible about your situation ..real very crazy plumber ..listen ..i have many technician friends inside our copytechnet ..russian ..americanian ..english ..spain ..brazilian ..and some others ...and you know whey because l am special technician not as you ..fucking plumber ...hey i invited you come at my house to repaired my special w.c ..!!! .
                        it already looks like his kid is typing for him.
                        Why don't you get one of your russian friends to get it for you?
                        • JustManuals
                          • Jan 2006
                          • 9838
                          I give up, Whey?
                          • User Name
                            Awesome Sauce
                            • Nov 2009
                            • 405
                            F9 --> 06 --> 04
                            Try this Zaza! It's the LBP Fuser reset procedure.
                            I know it's been said before but I figure maybe if I make the letters really big and make it as simple as possible, he'll understand.
                            Just because you're not paranoid doesn't mean they're not out to get you.
                            O.o
                            WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
                            • zaza
                              MECANOGRAPHE
                              • Mar 2008
                              • 1095
                              well friend user name now l tray this solution but ..unfortunate nothing must be change it ..always this message appeared there ..tray n.1 ..add paper ...
