Panasonic DP-1820 producing light copies
  • mukozho
    • Aug 2025
    [Misc] Panasonic DP-1820 producing light copies
    I have a problem with a Panasonic Dp-1820 it is producing light copies ,l have changed drum,developer,toner but its still light,what could be the problem
  • JustManuals
    • Jan 2006
    • 9838
    Re: Panasonic DP-1820 producing light copies
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • User Name
      Awesome Sauce
      • Nov 2009
      • 405
      I had the same problem. Here's the thread I started: http://www.copytechnet.com/forums/pa...ht-copies.html
      What solved my problem was increasing f6-21 at intervals of 5 (-15 to -10 for example) and running copies until the they darkened. There are also some other suggestions others posted in my thread that could help if that doesn't.
      Good luck.
      Just because you're not paranoid doesn't mean they're not out to get you.
      O.o
      WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
      • mojorolla
        The Wolf
        • 2627
        Manually add toner until copy density is to your liking; then run the developer set up. You could also remove the LVPS and clean it. 2330/3030 have dirty LVPS causing light CQ all the time.
        • Magebomba
          • Dec 2008
          • 92
          There is a mod for faulty grounding of the drum flywheel on the back of the machine. Easy way to find out is to ground the flywheel to the frame with a paperclip while making a copy and see if it goes to black.
