Panasonic Workio DP 3530 code E05-11
  • jcontractor
    • Aug 2010
    • 247
    [Error Code] Panasonic Workio DP 3530 code E05-11
    Hi,
    I have a Panasonic DP 3530 with E05-11 Error code,
    I notice a legal paper behind the legal paper tray, all crushed.
    A lose sensor flag behind the paper tray (like a semi-circule sensor flag); the one witch sense the paper lower, intermediate and upper level when the paper tray is closed. It detects like a movement in the paper lift mechanism.
    This flag moves inside a series of sensors behind the paper tray, between the paper tray and the machine, near the paper lift mechanism inside the machine.
    I remove the paper, place the sensor flag in it's original position, and I simulate the paper tray in it's position.
    I notice that the gear that suppose to lift the paper doesn't move at all. The machine only gave me the same error time after time.
    It is some trouble reset code for this equipment?
    It is usual that paper lift mechanism to fail or I'm forgot (missing) something to check?
    Thanks in advance everyone.
  • ESTANISLAOWENENTON
    Re: Panasonic Workio DP 3530 code E05-11
    hello
    same thing happened to me 2 times
    the first time and ready to change the spc
    the second a technician and took her under
    the very dog that did not tell me
    but if you look at the fuses check them TARGET
    • jcontractor
      • Aug 2010
      • 247
      Originally posted by ESTANISLAOWENENTON
      hello
      Thanks for the advice.
      • mojorolla
        The Wolf
        • 2639
        This error can mean the F1 fuse on the SPC is blown. You should also check the wiring harnesses for trays 1 and 2 as they can pinch and cause this error. Also, a slight chance of a bad SC, but almost always the SPC pwb. You could try unplugging both feed heads and see if the error goes away. If it does not go away, you probably have a bad SPC. If the error does not show up with trays unplugged, you have a bad wire somewhere.
        • jcontractor
          • Aug 2010
          • 247
          I really appreciate your advice.
            that's the fuse
            RATE ME with 10 stars
            • HusnainSafder
              hello experts
              i am here to discuss the same problem
              please guide me where is the location of SPC for fuse checking.
              1st i was getting U7 Error.
              i disconnect the sensor and power on the Machine.
              now i am getting E05-11
              thanks in Advance
