panasonic dp 6010
  • ESTANISLAOWENENTON
    • Jul 2025
    panasonic dp 6010
    hi
    in DP6010 is supposed out 60 copies per minute, this, draws 32 per minute but not stuck
    when taken in the seventh copy duplex jams
    slow the machine works
    no printing, no ping
    change the SC, SPC, DRV
    REMAINS THE SAME
    Owe the help
  • mojorolla
    The Wolf
    • 2627
    Re: panasonic dp 6010
    If you are running duplex, the output speed would be approx. 30 copies per minute. Is there a code when it jams in the duplex?
      the machine takes 32 pages per minute in 1 1 or simple mode
      duplex out at that speed., 30 minute jams, j 31
      10 copies are removed in 7 jam
      thanks for the help
      remember is dp 6010
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
        • mojorolla
          The Wolf
          • 2627
          Any pages jammed on top of each other. One face up and the other face down. If you have this scenario and J31, you could have a bad clucth in the main drive motor.
            ummmmm evident
            thanks for your help
            will review this
            how you rated 5 star?
            • PanaTech
              • Dec 2008
              • 71
              you said it jams when you do 1 -> 1 (simplex) copy..... I don't think the duplex clutch has anything to do with it. You can try add weight in the actuator in the inverting unit. The inverting unit is the assembly underneath the the fuser unit. remove the cover (below the exit door) with 2 screws, then remove 4 screws to remove the inverter unit, you will see a plastic actuator in the middle of the inverter unit, at the side of the unit, add some weight, so the actuator can move back to the original position faster to prevent jam.
                appreciate your help
                the machine is 60 copies per minute but works 32 x per minute
                when work is not stuck in 1 1, although it works 32 x per minute, no jams, full, very good
                when working in 2 2 J31 attacks letter size
                legal, letter r very good full working
