Can you reset drum counts so it will not give warning to customer? I saw F8-25 in the book. It said that the counts will be reset and adjusts the Toner Density. This makes me think this is not a good idea. Just wanted to get as much life as possible. I'm new to Panasonics, so I'm not sure if I should try this. It looks like the warning light is based on the count down counter. Any input would be greatly appreciated.
DP-C262 Drum Reset
Re: DP-C262 Drum Reset
If you are trying to save money on the cost of the color drums you can modify the black drums to fit the color slots.Comment
To modify the drum you are looking at the front of the drum to the right of the drum it the hole for the locating pin cut the plastic out in front of the tab and pull out a small metal tab then the drum can be used in all four spots.Comment
yeah thats key, i believe they have some modification pics on google, i can probably upload some if need be on demonstrating how to do this, maybe a video?? = profit? lolComment
Just thinking out loud. So, with modification, you can use either the DQ-UHS36k or the DQ-UHN36k, both black drums, for color drums in the 213/262/263/264/322/323/354?
Also, how about the 406/306/266. Looks like they priced the color and black drum the same. Can the DQ_UHS36k or DQ-UHN36k work? Or am I asking for too much?Comment
I see now how to modify.
Yes we have been doing this with all models of the Panasonic color except for the xerox box.Comment
Thank you for your input. As I said before I am new to the Panasonic line. With your input I was able to inform my boss of a way to save $$$. Did I get an adaboy. No. But thats ok. Thanks again.Comment
