DP 4520 possesed?
  • copiman
    • Sep 2011
    • 861
    DP 4520 possesed?
    Hey everyone. I have a possesed machine. I only saw this once and resetting the machine off/on worked. They said it happens from time to time, so I thought I would research it a bit. The symptom is the op panel will go out, you will hear several clicks like a relay chatting, maybe 3 or 4 clicks. If this happens during a run, of course it jams. I saw it happen one time while I was there. Not during a run but at ready state. I know about the bulletin attached. I'm thinking interlock switches/sensors on the 5 volt line? The machine shows no code of any kind. The customer wants me to come take a look Monday. They were running church bulletins the day I went, but it ran fine while I was there and they had to leave. Any help or ideas would be great.
  • moderncopiertech
    • May 2009
    • 14
    Re: DP 4520 possesed?
    What code is it giving?
    • copiman
      • Sep 2011
      • 861
      No code. Just lcd display goes dead and there is a clicking niose, maybe 3 to 4 clicks, like a relay. Sounds like the relay is near the front of the machine. I saw this one time when the machine was not in use. I'm thinking interlocks. The call came in when they were running church bulletins. They had a few jam codes J83 and J81. I think this is due to paper curl. 8.5x14 duplexed for the bulletin. Alot of curl. I am going there this morning to see if I can recreate the problem. They were ready to go once they completed the bulletins, which Ran just fine while I was there. THANK YOU for responding!!!
      • copiman
        • Sep 2011
        • 861
        May have found it. On/off switch at front left of machine. Will order one.
        • copiman
          • Sep 2011
          • 861
          It was the on/off switch on the front of the machine. While on, if you pushed the switch, it would loose op panel and click (relay?). Then go back to ready state. I replaced the switch and all is good. I opened the bad switch and the contact lever was bent. I quess the thought was press harder when turning on the machine and it will warm up faster? Go figure.
          Thanks.
          • ESTANISLAOWENENTON
            I spend the same, but can not remember the model of panasonic
            adf in the paper is jammed and the machine is restarted
            the problem was in the jam adf
            change tires and ready
