dp-1820
  • gamalmehdar
    • Mar 2008
    • 55
    dp-1820
    i have dp-1820 panasonic its show the spanner red with out any error code and also the paper tray empty mesage ?
    i try to initializing the ram but still same? the paper is full in cassette but showing no paper?
    can any one help how can reset and resolve this problem.
    best regards
  • moderncopiertech
    • May 2009
    • 14
    Re: dp-1820
    Check to see if your paper lift motor has a cracked case . I have run into this before.
    • gamalmehdar
      • Mar 2008
      • 55
      Re: dp-1820
      its ok ,but why the spanner apear without any error?
      and how can configure the error code number?
      • JustManuals
        • Jan 2006
        • 9838
        Re: dp-1820
        Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads -
        Paul@justmanuals.com
        • mojorolla
          The Wolf
          • 2639
          Re: dp-1820
          Have you tried the fuser reset in service mode?
          • gamalmehdar
            • Mar 2008
            • 55
            Re: dp-1820
            i inter to service mode>f9>Ram initializing> all jobs clear.
            but same.
            is there any way to know what this error , and code number?
            • copiman
              • Sep 2011
              • 861
              Re: dp-1820
              but same.
              I had a 1520 do this Friday. If it has a wrench and add paper listed, do an F9-06 and scroll to 04 and reset fuser. The customer opened the cassette to remove jam when this occured. Tha add paper is covering up the code and the lift of the paper will not happen until code is cleared. Try F8-06 to view code.
