dp 4510 E5-60
  • ESTANISLAOWENENTON
    • Aug 2025
    dp 4510 E5-60
    hello
    I have a code dp4510 the E5-60
    revice fan and works well
    clean all the contacts, DRV, SPC, LVPS,
    stopped bothering me for a while, but become annoying and worse
    Now E5-60, E3-23 and E 3-60
    appreciate your help
  • jaybug
    • 25
    Re: dp 4510 E5-60
    LVPS or SPC ???? sounds expensive could be power at outlet
    • mojorolla
      The Wolf
      • 2639
      Re: dp 4510 E5-60
      All three items are powered from the DRV board. Check the voltages at CN764 for the waste toner and CN758 for the fans.
        Re: dp 4510 E5-60
        thanks for the answers
        I've changed, drv, LVPS, fan etc and nothing
        I lack the spc
        wonder
        spc serves a dp 6010?
        thanks again
          Re: dp 4510 E5-60
          I've changed, drv, LVPs, fan etc and nothing
          I lack the spc
          wonder
          thanks again
          • copiman
            • Sep 2011
            • 861
            Re: dp 4510 E5-60
            Originally posted by ESTANISLAOWENENTON
            hello
            Did you get this resolved? What was the solution?
              Re: dp 4510 E5-60
              thanks for the concern
              cut a clip into three small pieces 4 mm connector you got into the three separate these and ready to run
              but the other day I was called away in 4520 with a e4 10 e3 24 e3 21
              I did the same but did not work, change ALL CARDS
              and nothing
              LES good thing was that I sold two DP 8045
              THAT'S throw away, 1,354,000 COPIES WAS
              thanks
