Hello ..l have error code E03-40 in PANASONIC DP6010 pls can anyone help me or sent me her sm in my email : mecanographe@gmail.com
PANASONIC DP6010
ESTANISLAOWENENTON
Re: PANASONIC DP6010
[QUOTE=zaza;261959]thx my friend ..but it have any other raison for this problems like the developer is bad ? pls l need the service manuals for this machine ?[/Q
this code is the image sensors
are in the drum unit
recovery blade is damagedUOTE]Comment
Your copy density sensors have toner on them.They are located under the rear side of the drum. You will need to replace the toner scoop, side seals, cleaning blade and possibly drum.Also if your dev is old and copier overtoned, you will have to replace the dev.
Th.Comment
