As the title says, I have an 8060 with a constant U9.I have replaced the sensor 3 times and verified the operation of the actuator.I have physically blocked and unblocked the sensor.I have my 5 volts and ground going to the sensor.I can monitor the signal to a certain degree and there is something there.I go to F4-005-4 and the signal does not toggle.I have verified on another machine that this is indeed the U9 toggle.I pulled the harness, one of the easier harness in this box, and ohm'ed it out.It is just your standard 3 wire harness and all continuity is good. No sign of damaged wiring.So today I just swapped out the DRV board.And I get exactly the same thing. A constant U9.Yoda. Help!!
Doug
