DP 3030 Fax forwarding
  • copiman
    • Sep 2011
    • 861
    I have a 3030 that I will need to set up fax forwarding. The customer wants to prevent all the junk that prints out. I know you can have the faxes forwarded to a persons email address, but have never done it. Looked in the svc manual and op manual and am more confused. I have set up network printing, scan to folder, scan to email on another manufacturer. Anyone have any step by step documentation? Or any help would be great.
  • Sama
    • May 2010
    • 18
    Re: DP 3030 Fax forwarding
    If you want to set up fax, fax to email,....
    your machine need to have something such as:
    - Fax module
    - Fax card
    - HDD
    • mojorolla
      The Wolf
      • 2609
      If you are forwarding to email, you will need to setup the SMTP settings first. Once that is done, all you have to do is enter the address you want to forward to once fax forward is enabled. If you want a desktop scan, download and install the Panasonic Communication Utility on the PC. Once it is installed, it will find the machine and add a button to the address book for scanning. It pretty much installs itself.
      You need the fax/email settings manual I believe. I think it is the one that lists all the settings for this issue.
      You could as set up hold to memory for faxes. That way they could print out the ones they want, and delete the spam.
      • copiman
        • Sep 2011
        • 861
        Thanks Mojo. Yes, forwarding to email. Let me see if I got this right.
        1. Enter SMTP server name or IP in user parameter 06.
        2. Enter email address into address book.
        3.Set Fax Parameter 54 to "valid" and select the email address in the address book.
        Does this sound right?
        • mojorolla
          The Wolf
          • 2609
          Sounds about right.
          • copiman
            • Sep 2011
            • 861
            Thanks Mojo. Will be going next week to do this. Thanks for your help.
            • onetek
              • 318
              If you use smtp name, dont forget to set proper dns in general settings....
              Th.
              • copiman
                • Sep 2011
                • 861
                Th.
                Thanks onetek.
