DP 8035,45,60 question
  • copiman
    • Sep 2011
    • 861
    03-19-2012.pdfShould the mylar, item # 1864, actually ride on the drum? See attached doc. to see item # 1864.
  • mojorolla
    The Wolf
    • 2634
    Re: DP 8035,45,60 question
    The only "mylar" to contact to drum is the lower drum seal. In this .pdf, it is item # 1817. I could not find #1864.
    • copiman
      • Sep 2011
      • 861
      Thats what I thought. Looks like I will just remove it. In your opinion, do you think I need to order it and put it back on? As always, thank you for your response. Looks like the panasonics are fading away.
      • ESTANISLAOWENENTON
        ADIFFERENCEOFTHIS MACHINEDP4510,DP8035LA,45.60, THECROWNOFCHARGEdirty,BLACKCOPY
        THISMYLARnot get it,so she placeddouble-sided tape
        SEALSAND CHANGESIDES1850and1813
        I HOPEYOUSERVETHEIDEA
