Hi Guys,
I just wanted to pass along my best feed roll tip.
I got this from an engineer many moons ago.
Once you clean the rollers with alcohol, take a drop or two of oil and rub it into the rubber.
After a bit, you will notice that your rollers now have a huge amount of grip.
The explanation was that if it is a Japanese box, then it uses synthetic rubber rollers which age differently from natural rubber rollers.
Just for grins and giggles, try it on the ADF feed and pick-up rollers for a test.
This works on most of the grey and black rollers. On really new machines I have been seeing these new type, kind of clear looking rollers. With these, it does not seem to work as well but I do not have enough boxes out there to test with any certainty
I use Castrol 5W-50 Synthetic.
It does seem counter-intuitive but give it a try.
