Panasonic DP-C264 Add toner problem
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    Hello everyone,
    I have a 264 that keeps asking for black toner but the bottle is full. The customer can get the machine running again by taking the toner bottle out, shaking it, and then putting it back in. I've checked for any obstructions in the toner path and there aren't any. The toner hopper/motor has been replaced and so has the drum. So, the problem must be in developer? Also, how does the machine determine the percentage of toner left in the bottle? There doesn't seem to be any sensors to detect this percentage, so I'm just curious. Any ideas or suggestions are greatly appreciated.
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
  • mojorolla
    The Wolf
    • 2660
    Re: Panasonic DP-C264 Add toner problem
    Try resetting the counter manually. FUNCTION, COUNTER VIEW; scroll to numbers 30-33. They are for clearing the 4 toner carts.
    • User Name
      Awesome Sauce
      • Nov 2009
      • 405
      I've never had to clear counters for toner before, but I'll give it a try.
      Thanks.
      O.o
      • copiman
        • Sep 2011
        • 861
        Hey User Name. I ran into this some time ago. I posted my problem and received 3 pages of posts. Take a look at it and i think this will help you. In my case, I aligned the gears on the dev unit and it solved my problem There is an attachment on one of the posts for this. I originally posted it 12-15-2011. Title was DPC354. Hope this helps. Let us know what fixed it.
        • mojorolla
          The Wolf
          • 2660
          They are designed to be auto resetting but sometimes they need a lil goose.
          • User Name
            Awesome Sauce
            • Nov 2009
            • 405
            I checked out your thread. I vaguely remember reading over it before. I went back and checked the gears. These were alligned before but I checked them anyway and they're still fine. I decided to switch the TDC sensors of the cyan and black developer units. If the problem was with that, then it should move over to the cyan and then I'll know if that's the problem and I can replace it when confirmed. Other than that, I'm not sure what it could be. I'm not sure about the firmware, but I don't think that's the problem. Oh well, now I wait and see what happens.
            O.o
            • User Name
              Awesome Sauce
              • Nov 2009
              • 405
              ...sometimes they need a lil goose.
              How about a regular-size duck?
              O.o
              • mojorolla
                The Wolf
                • 2660
                They should relabel them Goosasonic!!!
                • User Name
                  Awesome Sauce
                  • Nov 2009
                  • 405
                  I see what you did there.
                  O.o
                  • vedder
                    • 131
                    Hi, I had a similar problem to this, I made sure the gears at the back were correct as per bulletin, firmware was up to date, the only thing that fixed the fault was re deving the black, it hasn`t come back in since, and it has been months.
                    Hope you get it sorted.
                    • User Name
                      Awesome Sauce
                      • Nov 2009
                      • 405
                      By "re deving" do you mean recalibrating the old developer or replacing it?
                      O.o
                      • User Name
                        Awesome Sauce
                        • Nov 2009
                        • 405
                        Update: This seems to have done the trick. I checked the error report and there hasn't been a U13-4 code since I've done the swap. However, there haven't been either U13-3 codes either but this customer does many more black copies than color copies so I'm not totally surprised by this.
                        Thanks again everyone!
                        O.o
