Embeded Web Server password reset on Panasonic DP-C354/DP-C323
  • ewinnick
    I need to know if someone can tell me how to reset the password for the embeded web server on a Panasonic DP-C323. Someone was able to access the interface by IP address and use the default username (root) and password (0000000). But they then changed it from the known default to something that no one in the office knows. The person that changed it has since left employment and now we need to access the web interface. Is there a way to change it from Service Mode?
  • doug94550
    • Dec 2011
    • 138
    Re: Embeded Web Server password reset on Panasonic DP-C354/DP-C323
    I did some checking. For the best I can see, there is no way, through Service Mode, to reset/restore these parameters.
    Doug
    • mojorolla
      The Wolf
      • 2627
      The only way to obtain the password would be to use Network Configuration Editor software. You need the tool and the model module loaded. It will show you all the passwords in the machine.
      Download | Digital Imaging System | Office Products | Business & Professional | Support | Panasonic Global
      • ewinnick
        @mojorolla thank you for the info. I did not have a chance the get the software but did find a way to get/reset the password in service mode.
        Note: The password can only be 7 characters long.
        To exit the Service Mode:
