dp 2330 developer spill
  • DUKEEMURPHY
    • Jul 2012
    • 10
    [Misc] dp 2330 developer spill
    i have a dp 2330 that i just replaced the developer, drum, and cleaning blades on as soon as i turned the machine on it promptly spilled all of the new developer and went to an error code e03-03 i followed the destructions to the letter and cant come up with anything that might be wrong. no loose or dirty contacts thanks in advance for any help i can get on this one
  • JustManuals
    • Jan 2006
    • 9838
    Re: dp 2330 developer spill
    Paul@justmanuals.com
    • mojorolla
      The Wolf
      • 2606
      If you changed the charge roller, there is a metal grounding clip on the white plastic holder. Make sure it is not bent over.
      Also, check the two sensors in the right door. They should move up and down freely. If the bracket is put on wrong, it will keep the sensors from moving.2330.jpg
