Hey guys,
Last Friday I did some work on a Panasonic DP-8035. I changed the drum, dcb, developer, fuser web, corona wires, toner waste container and feed rollers for tray 1 and 2. After changing the fuser web, drum, dcb, corona wires and developer I turned the machine on and performed a TDC adjustment. After the adjustment, the machine printed out a few documents that were in the queue and they looked great. I turned the machine off and removed the paper feed mechanisms for tray 1 and 2 and replaced the feed rollers. I re-installed the paper feed mechanisms and replaced the toner waste container in the back with a brand new empty container. I put the panel back on and turned the machine on to see that it has an error code U9 and it instructed me to close the left cover. I looked up the error code U9 and discovered that it was, in fact, an open left cover.
The only things that the service manual tells me are:
I have opened and closed the door multiple times, replaced the left cover sensor with a known working sensor, traced back the wires from the sensor to the DRV board and disconnected and reconnected the connector on the DRV board, along with turning the machine off and on multiple times and trying a different power source. I am now lost as to what to do and any help would be GREATLY appreciated!
- Left Cover is Open.
- Left Cover Sensor is disconnected.
- Left Cover Sensor is defective.
