DPC 354 SC board replacement
  • copiman
    • Sep 2011
    • 861
    I need to replace a bad SC board with one from another machine. I know that data needs to be transfered. The problem is I have never done this. I know about the counter back up on page 234 of the manual, but I think this is for leaving a SD card on the SC board and it will back up counters 6 times a day. Is there a way to use a SD card in the front of the machine to back up data needed from the bad board to the SD card and then restore the data to the board I install. Keep in mind the board I will be installing is from another machine. I think the F9-20 and F9-21 may have something to do with it, but I'm just not sure. Other manufacturers I worked on had instructions for this. Any help would be greatly appreciated. By the way, with the bad board, the machine functions. It just will not recognize the hard drive and scan option.
  • JustManuals
    • Jan 2006
    • 9838
    Re: DPC 354 SC board replacement
    Paul@justmanuals.com
    • mojorolla
      The Wolf
      • 2583
      If it will not recognize the HDD, check the power board that comes with the HDD kit. I have seen a few of these fail over the years.
