Fuser code
  • luis8832
    • Dec 2008
    • 250
    [Error Code] Fuser code
    Working on a Panasonic UF-8200 and it has an error code of E041, i dont have a service manual for it so i was wondering if anyone out knows if this unit has a fuser reset in the service modes. Any insight is greatly appreciated.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Fuser code
    Paul@justmanuals.com
    • Has Been
      • Nov 2012
      • 48
      Re: Fuser code........Try 06 LBP Reset
      Code Function Check Points
      E4-01 Fuser Warm-up Temperature 1. Fuser Thermistor is dirty.
      2. Thermistor position is incorrect.
      3. Fuser temperature is low.
      4. Thermistor is defective.
      5. Fuser Lamp connector is disconnected.
      6. Fuser Thermostat is defective.
      7. Fuser Lamp is defective.
      5.2.6. Fax Service Mode 6 (RAM Initialization)
      Initializes RAM and restores the Function Parameters to their default values.
      Note:
      RAM Initialization Table
      No. Initialize Mode Description
      01 PARAMETER INITIALIZE Restores the Fax and Function Parameters to default
      values.
      02 JOURNAL CLEAR Clears the Journal contents.
      03 AUTO DIAL CLEAR Clears the One-touch, ABBR Numbers and Phone Books.
      04 PROGRAM DIAL CLEAR Clears the Program keys.
      05 LOGO/ID/PSWD CLEAR Clears the Logo, ID, Polling Password.
      06 LBP ERROR LOG CLEAR Clears the Printer Error Log.
      07 SHIPMENT SET Deletes all setting information, except parameter number
      80 and 81, then set default values.
      08 FLASH MEMORY CLEAR Deletes all information in the Flash Memory.
      09 ALL JOB CLEAR Clears all Jobs stored in Flash Memory.
      • mojorolla
        The Wolf
        • 2583
        Re: Fuser code
        You need the LBP FUSER RESET in F9 service mode.
