Hi, Anyone knows whether emptying the dp-C264 toner waste container will work? Thanks
Panasonic dp-c264 Toner Waste Container
Re: Panasonic dp-c264 Toner Waste Container
Probably not unless you vacuum it out. Look on the backside of it and you will find the clear window that fills with toner and triggers the "Waste Toner Full" indication. If that is dirty, you will get the message even if you have emptied it. -
I empty them out all the time. There's a seal/tape around the middle of the container you have to peel away and one screw that holds the two halves together. Once they're apart you can empty it out fairly easily. Make sure the clear tube on the bottom half is clean and when you rejoin the two halves, be sure that the auger is back in it's proper place. Then I just use black electrical tape around the seam where the two halves meet as a new seal. Works every time for me.
Good luck and try not to get too messy.Just because you're not paranoid doesn't mean they're not out to get you.
O.o
WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
Paul@justmanuals.com
Failing to plan is planning to fail!!!Comment
