DP C405
  • techman777
    • Aug 2025
    [Jamming] DP C405
    the paper stops at the registration rollers from all four trays and the bypass. But the copier will print out internal pages. any ideas? Thanks for your help.
  • NIKROTAS
    • Feb 2013
    • 16
    • techman777
      Re: DP C405
      That's what's strange about this, the machine doesn't kick a code it keeps on running until you open the right side door and see the paper sitting at the registration rollers. I remove the paper and close the door it clears and does it again. I have checked the history in service mode and nothing is listed. And yes I have reset the power a few times with still the same result. Thanks for your help.
      • copiman
        • Sep 2011
        • 861
        Re: DP C405
        Let me make sure I understand what you have posted.
        You can run internal prints, right? Exactly how are you doing this? Are you sending print jobs from a PC or using the service mode to print internal prints? If you can use service mode to print, go to F9 and print a "machine info" page. This will list codes that will help us help you. Is this the one you checked and nothing was listed?
        Also, if you try to make copies, regardless of drawer used, the paper stops at the registration sensor? Is the sensor actuated?
        Answer these and we can move forward.
        • tnrtt
          • 156
          Re: DP C405
          I've seen the same thing with an EC PCB.
