Color Copier DP-C264
  • mellon
    [Misc] Color Copier DP-C264
    Hi Friends, has anyone have a pic or a guide or a vid how we modify the black drum (DQ-UHN36K) so that it fit in color slots?
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    Re: Color Copier DP-C264
    Get a drill and find a drill bit that is just slightly smaller than the hole I've circled in red in the image above. There's a metal plate in there to prevent the black drums from fitting in the color drum slots, you want to drill through that. Be careful not to go too fast or you'll go straight through the plastic on the other side.
    That's the easiest way I know. Hope that helps.
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
    • mellon
      Originally posted by User Name
      [ATTACH=CONFIG]22317[/ATTACH]
      Awesome, i cant tell you how you helped me out. I hope i can return that happyness in near future.
      Thanks a lot
      • tnrtt
        • 150
        You can break the housing by the hole. The plate just floats and can be removed.
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
          Paul@justmanuals.com
          • alesi
            • Jan 2012
            • 1
            There is an easier way. Remove the metal locating pins from the machine that stop the black drum from going in far enough in the colour slots. Use pliers and they will just come off and then you can use the black drums in any slot.
            I have been doing this for years now and only once have I found the yellow drum sat too low as it is not sitting on a locating pin. You can just prop it up if the yellow fades towards the bottom of a print. Never had a problem with cyan or magenta units moving.
            Hope this is of help to somebody.
