panasonic dp-c213 error
  • ben_hartson
    i have a panasonic dp-c213 and sometimes getting the error E3-22can anyone help me ?
  • copiman
    • Sep 2011
    • 861
    Re: panasonic dp-c213 error
    E3-22 is a "Toner Cartridge Fan Error. Could be the fan (most likely) or the EC PCB (least likely). It located on the left side as you view the machine from the rear. You could swap out on of the other fans with this one to see if your code changes to see if its the fan. But most likely it is the fan. Replaced a few on this series machine.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      paul@justmanuals.com
      • mojorolla
        The Wolf
        • 2639
        This is a known issue on this model. You need to replace 2 fans; the fuser fan (front right of machine), and the toner fan (behind the SC pwb).
        • pacman
          I can turn a screw...
          • 318
          What Mojo said. Board probably isn't the issue.
          • mojorolla
            The Wolf
            • 2639
            I have changed this fan combo at least a dozen times. If you only change one fan, the other usually codes in a few weeks.
            There is a real easy way to check the EC board. Remove the rear panel. On the EC board, there are a series of 4 LEDs (orange and green I think, it's been a while) each representing the presence of voltage. If any of these LEDs are missing, the EC is bad.
            • nkprl
              • Sep 2013
              • 21
              the guys above are just right , same thing happened to me and changed the 2 rear fans and everything is OK
