Panasonic DP8016
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] Panasonic DP8016
    hello l have this problems in Panasonic DP 8016....l informed you ..l change the drum and blade cleaner ..also l clean all parts of this machine......always this black line appeared there in same place ..please help ...DSCI0002.JPG
    BEST TECHNICIAN . NICE PEOPLE .
  • Logged-on
    • Sep 2010
    • 197
    Re: Panasonic DP8016
    Does your problem occur on internal prints, or only when copying, if only when copying, then does it occur off the glass or through the ADF?
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      this machine not have the ADF ....all parts is good ..new Drum ..new blade cleaner ..new fusion roller ...please help ..
      • copiman
        • Sep 2011
        • 861
        It looks like what we call smoke line. Hard to tell from the picture. If so, its the charge corona wire. Try changing the corona wire. Is the line developed on the drum? Stop the machine when the paper is over the drum and see. If nits not on the drum then its not the wire. Then stop the copier when the paper gets to the fuser and see if that is where its coming from. Let us know.
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          well l said you l change the fusion roller by another new ...otherl change the wire of corona ....and l more clean of charge roller ...but any news ..please help ...
          • JustManuals
            • Jan 2006
            • 9865
            Paul@justmanuals.com
            • copiman
              • Sep 2011
              • 861
              Sorry zaza, missed the fusion roller. We need to know the following in order to help.
              Also, you did say you replaced the charge wire, right?
