Dp-c264 white line on yellow colour
  • nkprl
    • Sep 2013
    • 21
    when i print colour copies a white line appears especially on yellow colour. I've changed drum (y) but still the same ,, any thoughts?DP_C264.pdf
  • copiman
    • Sep 2011
    • 861
    Re: Dp-c264 white line on yellow colour
    My first guess would be dev unit. Do you have one you could temporarily put in to test? maybe from another machine.
    • nkprl
      • Sep 2013
      • 21
      No i don't have another to test it ,but i'll take it off to see if there is an optical sign or something ....
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • mojorolla
          The Wolf
          • 2627
          Remove the yellow drum unit and you can shine your light down and inspect the dv mag roller without gutting the machine.
          You can also go into F1 service mode and print patterns 18-21 to check the individual drum surfaces.
