hi all I have a panasonic dp8016 machine that produces light copy so we need darker this copy please remember me when l find the solution ..l can enter in save mode ....what section l trying there F1......F9....
Panasonic DP8016
Re: Panasonic DP8016
What's the count on the developer? Those are only rated for 60,000 pages and they don't last much past that.
I use F6-21 to darken the copies if it goes light prematurely. More positive = darker. Good Luck!Just because you're not paranoid doesn't mean they're not out to get you.
O.o
WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
well friend l making the new developer in developing unity and l making the new toner cartridge ..original but all copy is appeared light not good darker ...BEST TECHNICIAN . NICE PEOPLE .Comment
So, you changed the developer and it's light now? Was it light before you changed the developer? Did you change the drum too? Did you run F8-09 after you changed the developer?Just because you're not paranoid doesn't mean they're not out to get you.
O.o
well all is new ....drum ..blade cleaner ...toner ..developer ....fusion ....and l clean all different section of this machine ..sensor...mirror...well l do this operation F8-09 but anything must changing there ...please help .BEST TECHNICIAN . NICE PEOPLE .Comment
I'm not sure what to suggest as I've never had one that was light immediately after a drum/developer change. Someone else will probably have some ideas though. Good luck zaza.Just because you're not paranoid doesn't mean they're not out to get you.
O.o
