Panasonic DP-C264 Password Issue
  • Reprint01
    Hi Guys,
    I recently brought a DP-C264 at an auction, when I bought it home it is requesting a password when I select the copy button.
    Also I can access the service mode but then are asked to enter a password...
    Is there anyway to reset this machine to the default passwords?
    Thanks in advance
    Ronald
  • JustManuals
    • Jan 2006
    • 9838
    Re: Panasonic DP-C264 Password Issue
    Paul@justmanuals.com
    • mjunkaged
      • 383
      Originally posted by Reprint01
      Hi Guys,
      Thanks in advance
      Ronald
      Tried removing the battery? I think there's one in the control panel, but without looking in a manual, I cannot be sure. Power down rear power and wait 60 sec., remove battery, wait another 60......???
      • User Name
        Awesome Sauce
        • Nov 2009
        • 405
        Turn off departmental counters. Go to the functions menu, then general settings, scroll down to the bottom to key operator mode. The settings for departmental counters is in there somewhere, I forget the exact numbers now. The default code is 0000 to enter the key operator mode.
        Just because you're not paranoid doesn't mean they're not out to get you.
        O.o
        WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
        • dannydub
          • Feb 2014
          • 16
          Try 00000000 or 19660000 or 00001966
          Good luck
          • tonerleak
            • Mar 2012
            • 67
            The older Panasonics used 0000, the newer ones use 0000 0000, and some that have a security kit installed use 12345678 as a password. hope this is useful.
            • tnrtt
              • 156
              Hi Guys,
              Thanks in advance
              Ronald
              Default password is 00000000 for key op and service mode. If service mode password has been changed, you need a new SC PCB. If you can access service mode, go to F5-42, select no. Exit service and it shouldn't ask for a code any more.
              • Reprint01
                Hi Guys,
                Thank you for your help, I have managed to remove the password as per the information supplied.
