dp 4510 fax to e-mail pdf ?
  • JOEBOOROCKSYOU
    • Jan 2008
    • 85
    can any one tell me if the 4510's scan or fax in pdf format.
    and not tiff....??
    joeboo
    onestop wholesale
    phoenix ,az
    623-878-1616
  • just a tech
    • Jan 2007
    • 332
    from what i've seen, i believe it's tiff.. check out the specs.. www.panasonic.ca/english/office/copier/pdf/DP_4510.pdf
    • JOEBOOROCKSYOU
      • Jan 2008
      • 85
      Thanks Bro , You Saved The Day Again....
      • WWMAINT
        With the 4510 you can scan to email or folder in pdf format as long as you have the scan option install.
        You would change the file format under fax parameter.
        • PanaTech
          • Dec 2008
          • 71
          If you have the scanning function, you can change it to scan to PDF.
          That is in Fax parameter #177 <- (if not 177, it would be somewhere around there)
          it is called XMT File Type.
