Panasonic dp 1510 ADF problem
  • nkprl
    • Sep 2013
    • 21
    problem with adf unit
    please see attachment
  • copiman
    • Sep 2011
    • 861
    Re: Panasonic dp 1510 ADF problem
    Are you scanning portrait or landscape? Does this only happen when you use the ADF? Does it jam in the ADF?
    • User Name
      Awesome Sauce
      • Nov 2009
      • 405
      Answering copiman's questions would definitely help us help you but at first glance it looks like it's stalling while feeding through the ADF to me. A slipping clutch perhaps? I would take off the covers and run the ADF test mode (F8-47) and see if you can see any of the clutches stop engaging or if the paper runs into anything. Although, the test mode in that machine is going to automatically do duplex scans just so you know.
      edit: Actually, what kind of ADF does that machine have? Being that it's a 1510 it probably doesn't have the duplexing ADF.
      Just because you're not paranoid doesn't mean they're not out to get you.
      O.o
      WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
      • nkprl
        • Sep 2013
        • 21
        I am scanning landscape
        when i scan portrait its ok
        it only happens on ADF and doesnt jam
        • nkprl
          • Sep 2013
          • 21
          i think you are right something is stalling
          i tried f8-47 but nothing happened
          • copiman
            • Sep 2011
            • 861
            If it were me I would make sure the ADF is flat from front to rear. Make sure your rollers and sep pad is in good condition. Try another clutch. I looked in the parts book and only saw one clutch for the ADF. If you do not have one, there are some in the copier you can use to test with. Do a search in the parts book for DZGA000007. There are many in there. This way you can be sure its the clutch before you order one. User Name is correct, you have something stalling.
            • User Name
              Awesome Sauce
              • Nov 2009
              • 405
              It's been awhile since I ran F8-47 on one of those but in order for it to work I believe you need to have paper in the ADF. Otherwise it won't do anything at all.
              O.o
              • NIKROTAS
                • Feb 2013
                • 16
                check the roller, clean with soft cloth and water all rollers
