Panasonic DP-C264
+ More Options
Posts
  • Buddy
    • Aug 2009
    • 285
    Panasonic DP-C264
    Hi Guys,
    I have very little experience...OK, I have NO experience with this machine. My customer has complained about a "green line." I assumed they had a bad drum blade, but it doesn't appear to be. The line doesn't drag across the page. (Like a bad blade would.) the line just appears in the image area.
    I have attached two samples.
    Any help would be greatly appreciated. Thanks
  • 20gaugeO/U
    • 557
    Re: Panasonic DP-C264
    Clean the optics. They are very prone to the smallest pieces of dust on the mirrors and/or slit glass.
    or
    Use the laser glass cleaning rod located in the front door
    or
    Run individual colors C,M,Y and see if one of the drums has a line
    • Rick Martinez
      • Sep 2009
      • 77
      or
      or
      I just had the same thing happened to me last week on a yellow drum, the line came from the drum.
      • Buddy
        • Aug 2009
        • 285
        Hi Rick,
        Did your line stop at the image, or did it run into the void areas? Thanks
        • Rick Martinez
          • Sep 2009
          • 77
          Originally posted by Buddy
          Hi Rick,
          it did went over the void area too.
          • JVergin
            Service Tech / IT Rep
            • 216
            It could also be a rotational mark on the charge roller, maybe not bad enough to create a line across the page, but enough that it's noticeable through the printed image. I've been successful cleaning charge rollers with a little simple green on a cloth. Make sure to get all of the lint from the cloth and any dust off the charge roller or you'll get repeating dots on the page.
