Panasonic UF7200 U13 code
  • mikez
    • Oct 2012
    • 30
    [Error Code] Panasonic UF7200 U13 code
    I have fax constantly throwing a u13 code even after replacing with a new toner cartridge. Tried all the normal things cleaned this and that checked power. We don't really work on fax machines anymore and just ordered this one for a good customer and of course it's biting us in the ass. Any help would be appreciated.
  • laitang
    • Nov 2012
    • 627
    Re: Panasonic UF7200 U13 code
    When replacing with a New Cartridge, perform the steps below to reset the Print Counter.
    1. Press "FUNCTION" key.
    2. Press "7" and "8 keys.
    3. Press "SET" key.
    4. Press "5" to enter "05 TONER REPLACEMENT? PRESS SET TO SELECT".
    5. Press "SET" key, then "TONER REPLACEMENT? 1:Yes 2:No".
    6. Press "1" key to reset the Print Counter.
    7. Press "STOP" key to return to the Standby mode.
    • onikaiser
      3. Press "SET" key.
      thank you for the info
