4520 - J61
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    [Error Code] 4520 - J61
    I have a Panasonic 4520 that keeps giving the J61 code (Stapler not activated correctly). Tried switching out the staple unit and, when that didn't work, took another finisher that I know doesn't have any issues and I still get the code. So, the issue must lie with the machine itself. Any ideas on what the issue may be? I'm thinking it's a logic problem with one of the PCBs. I'm not terribly good at diagnosing PCB issues so if anybody has some advice, I'd appreciate it. Thanks in advance!
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
  • laitang
    • Nov 2012
    • 627
    Re: 4520 - J61
    Is firmware up to date?
    • User Name
      Awesome Sauce
      • Nov 2009
      • 405
      Re: 4520 - J61
      Probably not. We've never been Panasonic dealers and I don't have easy access to the Firmware.
      O.o
      • User Name
        Awesome Sauce
        • Nov 2009
        • 405
        Re: 4520 - J61
        Confession time: this wasn't my call but rather my coworkers'. The problem was that my boss decided we could use a different type of staples for a different machine in this one if we just put them in the old cardboard cartridge (they looked the same after all). Apparently, this is not the case. I thought I'd post here since I figured the staple cartridge would have been one of the things replaced at one point (nope, same one put in each time) and I didn't have any other ideas.
        Sometimes the answer is so obvious that you look right past it I suppose. :/
        O.o
        • tnrtt
          • 156
          Re: 4520 - J61
          It's definitely the staple cartridge. I've seen the same thing happen with different brands of after market cartridges.
          • User Name
            Awesome Sauce
            • Nov 2009
            • 405
            Re: 4520 - J61
            Yes it was. Hooray for non-OEM staples! :l
            O.o
