Pls help , E 03-10 what happen of this , don`t have menu , appreaciate and Thanks
DP 1520
Tags: None
Re: DP 1520
E03-10: High Voltage Power Supply leak (1) - Grid Charge Voltage
1. High Voltage Power Supply connector disconnected.
2. High Voltage Power Supply defective.
3. SPC PCB connector disconnected.
4. SPC PCB defective.
5. Corona Wire is abnormal. (Check for: contamination with foreign particles, broken, not installed in the proper position or loose tension)Comment
