DP4520 Fax Setting
  • Brian8506
    • 1664
    DP4520 Fax Setting
    Hi All!! Just jumped over here from the Canon forum. I got a new customer that lost his owners manual for this model and is trying to remove the sender name and phone #. He bought it used long ago so someone else's name is in it. I flipped through as much of the user modes as I could, couldn't find anything in the manuals I found online which were difficult to navigate. I thought maybe someone would have a simple procedure or be able to send me an owners manual. I believe the fax guide is a separate manual Thanks!!
  • onetek
    • 318
    Re: DP4520 Fax Setting
    Try "Function" , then "fax settings", then key op mode (0000 default) then "user settings"
    • Brian8506
      • 1664
      I tried that but couldn't find it. Maybe its under a category I don't recognize
      • User Name
        Awesome Sauce
        • Nov 2009
        • 405
        I believe #2 (Name) and #3 (Number) are the ones you want. The naming is a bit odd now that I think about it.
        Here's a printout from an 8060 in our shop for reference. Newer model but still the same thing.
        User Settings.pdf
        Just because you're not paranoid doesn't mean they're not out to get you.
        O.o
        WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
        • Brian8506
          • 1664
          Thanks. I'll try it
          • mojorolla
            The Wolf
            • 2596
            On a Panasonic that old, I believe the default password would be 8 zero's. (00000000).
            • User Name
              Awesome Sauce
              • Nov 2009
              • 405
              It's 4 zeros on the older models. It was the newer 80 series that started using 8 zeros I believe.
              O.o
              • Brian8506
                • 1664
                Thanks for the help. Customer took care of it
