Workio 3000
+ More Options
Posts
  • jake24482
    • Apr 2011
    • 116
    Workio 3000
    Can some one help me to set up network for workio 3000 like how to set ip in system how to get in to settings
    Thanks in advance
  • allan
    RTFM!!
    • 5462
    Re: Workio 3000
    Oops, tried to help worked on them years ago. do you run into a menu that asks a password? user manual refers to the administrator to give IP.
    Printing On Network - Panasonic WORKIO DP-130 Operating Instructions Manual [Page 73]
    Whatever
    • jake24482
      • Apr 2011
      • 116
      Re: Workio 3000
      i just need to know how to input ip address in to the machine in setting mode
      • disko
        Copier Guardian
        • Jul 2014
        • 34
        Re: Workio 3000
        Should be in function -> General Settings -> Key Op "0000" or "00000000" then navigate to IP Settings, I haven't been at these machines in a while.
        You should be able to enter the IP address in there, don't forget to power cycle the machine after inputting the settings.
        If you need access to the manual let me know though a PM (:
        Good Luck!
        • jake24482
          • Apr 2011
          • 116
          Re: Workio 3000
          Good Luck!
          i will try that
          thanks for the info
