Panasonic DP-1520 p
  • Tamyiapsoon
    replied
    Re: Panasonic DP-1520 p
    i want to Thank all of you ( onetek , Subaro , & laiting ) my customer machine DP-1520 P problem already solve , i have do clean registration clutch and adjust F6-07 , APPRECIATE
  • onetek
    replied
    Originally posted by subaro
    BELOW---this was posted in this forum some time ago.
    Is this the tech bulletin you refering to?
    On these copiers, ghost immages can also be caused by old drum/blade, or dirty heat roller due to non oem toner. also the charge corona can leave marks too.
    Th.
    lol, that was an old post of mine..! @Subaro :This fix and the shippment set are good ideas.
    Th.
  • laitang
    replied
    I think the registration roller clutch is stucked.
  • subaro
    replied
    Below is a bulletin that panasonic has for hv leak, this should be done. Just remove the fly wheel at the back ,get a piece of copper insulated wire and attach it the the frame. you don't have to buy the items listed there.
    GO to f5-14 and check all your paper sizes and make sure they are correct. also remove the tray and check the guides, that the are not broken and out of alignmentIf that fails go to f6 and record the 21 and 26 values and then do shipment set from f9 -6-3 choose not to reset counters.
    after shipment set, go back and check the f5-14 paper size. and check f6 21 and 26 has not change, if they do then put them back.
    the machine should print ok now. fine adustment for registration ect, someone else will have to help you. Note--- rebooting is caused by the hv leak.
    Th.
  • Tamyiapsoon
    replied
    Originally posted by onetek
    If paper size is correct, then get your F6-04(printer registration) and F6-07 (leading edge void) back to 0 and check again. Did the void change?
    Bos F6-07 already 0 , image lead edge alignment is o k , i thing main board problem now , machine restart it self , thank for help , i will tell customer no need to repair raedy , i seldom do panasonic brand
  • onetek
    replied
  • Tamyiapsoon
    started a topic Panasonic DP-1520 p
    Panasonic DP-1520 p
    front half blank , copy and print chart is same , pls help and thanks
