cant print through Computer DP-C265
  • aliasif83
    • Mar 2015
    • 11
    Hi
    I have panasonic DP-C265 Copier i cant print through computer i have installed all the drivers it dosnt even print a test page when i send print to copier copier starts for 10 to 15 second but dosnt print and when i check print history it says Code Unmatch
  • onetek
    • 318
    Re: cant print through Computer DP-C265
    Do you ave department codes turned on for printer? if so, input your code in the drivers properties, job type.
    • mojorolla
      The Wolf
      • 2627
      What drivers are you using?
      PCL and PS are options on most DP-C models.
      • aliasif83
        • Mar 2015
        • 11
        i have tried both PCL and PS but i am having same problem with that
        • subaro
          • Oct 2010
          • 1274
          Is this machine in your shop or customer site, and where are the print jobs been sent from, server or standalone computer ?. take your laptop and crossover and in stall the drivers and see what happens. You have said very little what you have tried or attempted. can you ping the machine ?. If you are asking for solutions, you have to provide as much info as you have done.
          If you have corrupted drivers, you will have to get a program to clean the registry of bad entries. seen this many times and have rectified this by uninstalling the driver and reinstalling by a utility i use and it produces results.
          If you provide all what you have done Mojorolla will solve this for you, he is the panasonic guru as i see from all his panasonic replies.
          • onetek
            • 318
            As said before, remove your drivers (go to printers, server properties, remove drivers from there too). Then go here Download - WORKiO DP-C405, C305, C265 | Digital Imaging System | Office Products | Business & Professional | Support | Panasonic Global and download PCL driver (standard for DP-C265, PS is option).
            Th.
            Ps: on the copier, make sure F5-42 is set to "no" to do your tests.
            • aliasif83
              • Mar 2015
              • 11
              here is the result
              I have 3 computers i tried on all of them
              In New PC
              i installed the PCL driver from panasonic web site i chose the USB Drivers after successfully installing the drivers it communicate with the printer when i send Test Page to printer it starts and it just stuck at processing and when i send the test page again it stuck at spooling and Pint Data Green light just Flash
              • aliasif83
                • Mar 2015
                • 11
                here is the second Computer
                Printer is connected through Router with RJ45 cable i set the IP address Subnet Mask and Default gateway according to the instructions and when i ping that IP it Reply the connectivity is good
                I installed PCL Driver this time i choose Network Driver and i installed the network drivers successfully and when i sent the test page or other file to print it says Dept. Code Unmatch
                • onetek
                  • 318
                  Remove department codes in F5-42 !!!!!!!!
                  Th.
                  • aliasif83
                    • Mar 2015
                    • 11
                    Third PC
                    I tried on a network computer
                    I installed PS Drivers by selecting Add Printer. Drivers Installed successfully when i ping it shows connectivity when i send a test page printer starts and then the status is same. Dept. Code Unmatch
                    the first pc in earlier post is connected via USB Cable direct in to the PC
                    all these computers they never had any Panasonic drivers before
                    any idea about this problem
                    • aliasif83
                      • Mar 2015
                      • 11
                      Th.
                      From where i can remove it can you please give me any idea
                      • aliasif83
                        • Mar 2015
                        • 11
                        how can i Remove department codes in F5-42
                        can you please help me with that
                        • aliasif83
                          • Mar 2015
                          • 11
                          its working i manage to turn off the code and its working
                          Thank you Guys are life saver
                          Thanks Again
