poor copy quality on dp-mc210 panasonic
  • dcooper
    • Nov 2014
    • 37
    Hi I was wondering if you have any suggestions on what to do? I have a DP-mc210 panasonic that I installed both monochrome drum and a
    color drum and a primary transfer belt unit and I am getting a copy and a print with several void lines down the page and the color is very faint
    when I do the color test print. I took the cover off the laser unit and cleaned the mirrors on the laser and it didnt touch the problem.
    The copier is in a dirty environment. The void lines are pretty much the same pattern with color copies and black copies. I took the unit apart
    where the CIS unit is but it looked clean and I am not sure how to clean the CIS though. I did clean the bottom of the glass.
