Workio DP 2330 E04-2 Error can't clear
  • Doug James
    • Jan 2012
    • 935
    [Error Code] Workio DP 2330 E04-2 Error can't clear
    It says in the service manual that this is an error caused by 5 jams in a row. I checked the #1 and #2 sensors and there does not seem to be a problem. I went through the service mode F1-F9 and there does not seem to be a way to reset it. The customer experienced the problem while running the machine. Not sure what is wrong with this beast... Any ideas are very welcome... Thanks so much !!
  • yakyitz
    • 245
    Re: Workio DP 2330 E04-2 Error can't clear
    In F9 select "parameter initialize" then go to LBP Fuser reset. Wait for prompt to power off/on and you're good to go.
    • Doug James
      • Jan 2012
      • 935
      THANKYOU SO MUCH !!!
