DPC262 density issue
  • madas
    • Aug 2008
    • 313
    Hi guys
    normally work on kyocera and canon but due to a tech leaving I've got the task of looking after a few panasonics.
    have the above model light on the cyan, density is low on test page and a little patchy, makes green look lime on my test chart.
    we will be replacing these soon so wondered what setting if any I could use to up the density or at least try just to get through until they are upgraded
    i have a manual but have not worked on these so am not sure which setting might work best.
    any help would be appreciated.
    cheers
    les
  • onetek
    • 317
    Re: DPC262 density issue
    You can try adjusting F6-522 (tdc gain adjust) to somewhere around 10 or 15, and F6-557 (tdc judg. level) to 10. After that, make some copies in F1-22. You'll probably get some toner out errors coz toner wont be fed fast enough, but you'll get your cyan back.
    • madas
      • Aug 2008
      • 313
      Cheers onetek, I will give that ago.
      les
      • madas
        • Aug 2008
        • 313
        Cheers onetek, that did the trick much appreciated.
        les
        • onetek
          • 317
          Glad I could help!
