RICOH MP 4500 light copies
  • Pulsara
    Technical Manager
    • Aug 2015
    • 27
    Hi friends! one of RICOH MP 4500 copier I'm servicing having an issue like this.Printouts & counter copies are very good. but photo copies & scanned images are very light. I have done drum, developer replacements, lazer beam adjustments..etc. no improvement.Adjusting to darkest position can get acceptable photocopy.any idea please!
  • StrippedScrew
    • Jul 2012
    • 58
    Re: RICOH MP 4500 light copies
    What does the image on the drum look like? Also if you open the left door and cheat the switch you can watch the patch roll around on the drum. Is it full density or poor fill? If the patch looks good the then you have a transfer prob, might need belt/blade
    • Zaxxon
      • 608
      Did you follow the correct procedure when changing the pcu and developer?
      Please start you post with brand, model, problem.
      • davel
        • Oct 2011
        • 1107
        Clean the optics, fixes it every time.
        • Iowatech
          Not a service manager
          • 3930
          You should try tweaking the scanner manual gamma adjustments.
          • bob marley
            • Jan 2012
            • 1339
            dirty optics
            Live for yourself and you will live in vain. Live for others, and you will live again
            • CrapAimer
              • 296
              Always clean the optics, amazing the problems it solves
