SC 492
  • brugge printshop
    • Aug 2015
    • 5
    [Error Code] SC 492
    can somebody tell me what to do. Have cleaned everything from developer unit to both waste toner thanks. Can make one copy and have SC 492 again.
    Thx
    Patrick
    • 37542
    Re: SC 492
    Tell us what the model of the machine is and then we might be able to help you.
    • brugge printshop
      • Aug 2015
      • 5
      Re: SC 492
      It is a Ricoh Afficio Mp 2090. It's a old machine
        • 37542
        Re: SC 492
        From Goose's guide:
        SC 492 replace toner suction motor
        SC 492 BCU defective
        Extract from the service manual on replacing the toner suction motor. Error could also be one of the 2 connectors going to the pump loose or the sensor bad.
        If you have cleaned the tube going from the development unit to the pump, I would replace the tube. It has a Teflon coating on the inside and cleaning can damage the coating and cause clogs.
        • brugge printshop
          • Aug 2015
          • 5
          Re: SC 492
          The suction moter is working en tube is already cleaned.
          Told you; i did everithing.
          Thanks,
          Patrick
          • Zaxxon
            • 608
            Re: SC 492
            Thanks,
            Patrick
            Nope, if you did everything it would be working
            Please start you post with brand, model, problem.
            • JonManchester
              Technician / Shop Manager
              • Aug 2013
              • 103
              Re: SC 492
              One thing you didnt do is replace that old machine, and even if you've done everything then why are you asking for help.
              Live for something or die for nothing.
                • 37542
                Re: SC 492
                Thanks,
                Patrick
                The error code has to do with not seeing a change in the sensor on the suction motor for 3 seconds. Either the motor is bad, the sensor is bad, the harness going to the sensor is bad or the BCU is bad. Unless you have replaced everything, you have done nothing. The suction motor should be replaced every 2.5M to 3M. The suction bottle should be replaced at the same time. If as you say you have cleaned the tube, then it must be replaced, unless you like toner hazing over the entire interior of the machine.
                • brugge printshop
                  • Aug 2015
                  • 5
                  Re: SC 492
                  .I try again tomorrow and let you now. Bur....it is the third time....
                  • brugge printshop
                    • Aug 2015
                    • 5
                    Re: SC 492
                    thanks!!
                    • bob marley
                      • Jan 2012
                      • 1339
                      Re: SC 492
                      SC492: Development Unit Suction Motor
                      Definition [B]
                      While the development unit toner suction motor is operating, the lock sensor output
                      does not change for 1 s.
                      Possible Causes
                      Motor lock due to overload
                      BCU defective
                      Live for yourself and you will live in vain. Live for others, and you will live again
