SPC 305 Add toner cyan
  • mannai
    • Aug 2025
    My spc 305 spf prompt with add toner cyan oftenly while copy or print. Even we replace with new toner cartridge many times. After removing cyan toner and re inserting back machine works normal.Replaced BRB board and updated firmware also. Problem remains same.
  • knarfdnul
    • Apr 2011
    • 27
    Re: SPC 305 Add toner cyan
    Have you opened the front while feeding toner? I have once had a bad toner motor - otherwise RTB on toner feed coil and.
    • Zeldaman
      • Mar 2011
      • 946
      • Zaxxon
        • 608
        If this is MP C305 I always change toner motor and hopper in pair - would hate to take it apart two times...
        Please start you post with brand, model, problem.
        • bob marley
          • Jan 2012
          • 1339
          agree with u
          Live for yourself and you will live in vain. Live for others, and you will live again
